Issue with note creation date
I tried using one of my siri shortcuts that relied in obtaining the creation date of a note.
It is obtaining the actual date and time, not the creation date, as it previously did.
Expected to obtain the created date, because it is essential for the shortcut to compare the name of the Agenda note with my obsidian periodic notes (if it already exists, etc).
Currently using the most recent version until this date, and happening on all devices.
Are you using Agenda 16 or 17?
Now using Agenda 17, but still having the issue. I found a workaround, where the shortcut obtain all dates within a note (text notes, creation date notes, etc). It looks better actually
OK, thanks for reporting it.
Here is the shortcut if you want to test it:
https://www.icloud.com/shortcuts/838dc764eeef42149ee8c00761e67ff3
@artehur I’m in a similar situation where I need to retrieve created and last modified dates to use in calcs for how long a note has been alive and/or unedited. I tried part of your shortcut and can’t seem to get the two to the clipboard. Any suggestions?
Many thanks.
