If it’s here, i’m pretty sure i missed it.
Is there a simple way to insert emojis while im writing?
Currently copying / pasting them from messages.
Use the emoji keyboard
How do I do this on a Mac?
It’s in the Edit menu
Here’s how…
I assume you know how to make that menu visible?
If you want to get access to emojis in an instant, I’d recommend installing the trial version of the KeyCue 9 cheat sheet. They have a special cheat tab for emojis. You can find them at ergonis.com.
Also Control–Command–Space bar. See Mac keyboard shortcuts - Apple Support
