I am doing a major reorganization of the way I use agenda. Prior to this process, I was not using tags, but I now need to use them. I am wondering if there is a way to select notes and batch insert a tag or tags into them.
In this specific instance, I have a semester’s worth of class meetings already set up—attached to calendar appointments, etc.— and I’d like to be able to select them all and tell Agenda to insert into them the tag #classes, rather than having to open each note and insert the tag by hand.
If there isn’t a way to do this, I am wondering if other people might have other use cases that would make this feature desirable.
Richard
