What I did: Pasted a link
What happened: Got a text from title of the webpage of the url
What I expected: I just want the url as it is. I know I can edit it later but it becomes a chore to do it every link I paste
Things that might be helpful to know (Agenda version, OS and model, etc): macOS 12.5 / agenda 14.1.1
Yes, the way to do this is to simply type a backslash character (\) and then paste, this should keep the link “as-is”. If a link has already been shortened, as you say can edit it (cmd-K) and the popover allows you to revert the shortened link, but the backslash trick will prevent having to do that.
PLEASE add preference to set default to paste links “as-is”. A lot of us prefer regular pasting NOT having to use “\” EVERY time
We’ll consider adding an option, thanks for the feedback
It appears any character entered (aside from a space) will stop the URL from being prettified.
Well, this doesn’t appear to be a consistent behavior. My apologies for suggesting it.
Bumping this as another request for a preference as to the default behaviour for pasting URLs. I paste a lot of URLs multiple times daily and the \ workaround is ok, but a growing pain. I’d like a setting to already show the full URL when pasting.
