Hi there - may be I got stuck, but I cannot insert a link in a note to a „numbers“ file in my iCloud. Using Agenda on an iPad Pro. Any idea how to do this?
I don’t think that will work on iPad. Perhaps if you can find the file in the web version of iCloud, it would be possible to make a link that way, but the local copy is not really a web link, and iOS doesn’t have a file system like macOS does, so you can’t easily link to files.
You want to be able to open a Numbers’ file via a link in Agenda?
If so, you will have to use the share option “share file in iCloud” (mind the options to obtain the link). This will give you a link to the file, which you can then paste into your note.
Hope this was of use,
Rob
