Inbox half hidden by top bar
A picture says more than thousand words :wink:
Thanks Martin.
So you can’t scroll it down? I guess you are not on the latest macOS. Which version do you have?
We’ll look into it.
Hi Drew,
I’m on macOS Tahoe Version 26.5 (25F71).
So I think it is the last version.
Hmm, are you using “reduced transparency” or something like that?
What you see in my screenshot is the default. But with reduced transparency turned on, the background becomes solid and probably does what you see.
Found it. Fix will be in 23.0.1
