Just installed Agenda
Trying to figure out if it will be sutiable to combine my homenotes and events as well as notes from an google education enterprise IT dept managed google calendar account. Can I import google calendars?
Agenda uses the calendar store of you devices. The calendar store is a shared database of events and reminders, and is basically controlled by the Apple Calendar app and system Settings app.
If you are able to get your Google Education events to appear in Apple’s Calendar app, they should automatically then appear in Agenda. That is the best way to test.
Hope that helps!
