What: I intend to switch to Dropbox to sync my Agenda notes
The issue: my iCloud free space is full
Solution: how to progress when instructions are clear that I should have enough space on iCloud?
To use Dropbox, install the Dropbox app on each device, and create a free account.
In Agenda, switch the sync to Dropbox in the app settings. On Mac, go to Agenda > Settings/Preferences, and in the General tab choose Dropbox for sync from the popup button. It should ask you to sign in to Dropbox. Repeat this on iOS devices, opening the right panel, and tapping the button bottom-left.
Hope that helps!
