paste a url, like TitleOfTheURL Some Description
Authentication is needed, the url will be redirected to an authentication server, and the text of the url will be changed automatically.
Can you give us some concrete examples of real world links, perhaps we can exclude some patterns automatically from being renamed.
Having said that, there are two solutions in this case. If the link has already changed to Sign in, the workaround is to right-click > Edit Link , then change the display text, or choose Display as Full URL in the inspector.
To prevent that this happens with newly pasted links you can first type a backslash character ( \ ) and then paste the link, this too will keep the link as is.
Sorry that our links cannot be visited from outside of our company, just a regular CAS server redirection. But it’s odd that google doc’s link won’t be auto renamed with 'Google Drive: Sign-in’ without signed in.
I wonder if there can be a switch to turn this feature off in Agendar’s Preferences panel.
The right-click > Edit Link way is driving me crazy…
That’s indeed because we recognise the pattern for some sites already, having concrete examples of links where renaming is unwanted helps us recognise more of them. Having said that, I’ve now added a more generic recognition of sign in and log in pages, which hopefully makes things a lot more reliable however. It should become part of the final 14.1 update, due out soon.
Maybe a better UX would be to have a preference that lets you set whether or not to convert URLs? I’m in a similar situation, and I prefer leaving my links as full URLs.
This did get fixed, BUT now it’s broken/gone again? Up until yesterday I was using the standalone installed Agenda and it worked just fine, but got prompted via pop-up to download the version from the App Store— did that. Now all the URLs don’t paste in as URLs, and I can’t find an option to make it stop doing this. What am I missing???
Not sure a preference is the right answer. The problem is, it depends per link what you want to do. It is not that one user wants always to paste the full link, and another always with the title. A single user may want to mix these. So a preference would only help the few people who, for example, always want the one or the other.
Sorry, just saw this reply! Yes, good point. Could this be solved by making the preference choices look something like this:
— Always paste in URL as URL
— Always transform the URL
— Ask me every time I paste in a URL
What do you think?
Thank you!
Help me out here. I really don’t get the reason for transforming the links in the first place, links can be named. If one wants to display the link itself that option is available in the link editor. For those that want the shortened version just add a “shortened or transformed” or whatever selection to run the routine in the link editor.
Also, most people don’t care about having links show up like https://www.google.com/search?client=safari&sxsrf=AB5stBj9LtMrWXmGCyhxGSl66CiELHZvGw:1691184438422&q=dk&tbm=isch&source=lnms&sa=X&ved=2ahUKEwiKn879-MOAAxURSvEDHQnGB1cQ0pQJegQIDRAB&biw=2011&bih=1112&dpr=2 if it could just be Google Image search for “dk”
