What I did: Searched for notes inside a project, with the filter last month applied. I see only notes from last month. I pressed the save button next to search all to create an overview.
What happened: The overview gets created but is not filtered down to the specifc project.
What I expected: The saved overview matches my previous search results.
- Agenda 14.1.1
- macOS 12.3.1
