Hi there,
I see in the Agenda 18 video that search terms / smart overviews are added to the “Overview” section instead of a separate “Smart Overviews” section. I like that! how do I get it?
(also you call it Trash instead of Bin…)
Hi there,
This depends on the number of smart overviews you have, if there are less than five they will appear directly in the Overviews section like shown in the screenshot, if you have more they will appear in a separate section to prevent the overviews section to grow too large.
Ps. trash is used in American English, bin is used in British English. Given I’m in Portugal the latter is physically closer and the system picks it as the default English in my region.
