How I use Agenda
I don’t know if you can call many small jobs for my computer repair clients “projects”, but that’s mainly what I have to record in my daily journal project. Sometimes, the jobs get really complicated and/or multi-day. I split those client notes off into a separate project/client note and then reference that specific note back to the daily journal timeline for however many days it takes. I also record personal occurrences in my daily journal.
I am working on converting my older 832 daily journal entries to a compatible format for import. Right now, I only have 2023 to date imported. The Apple Notes HTML Importer (an intermediate step I used for 2023) can only handle about 60 items at a time before it just stops responding, even on an M1 MacBook Pro.
I have so many short notice and small calls that I use a paper planner to schedule the clients I’m working with and personal matters for quick reference.
My Projects are really classifications, and they don’t really change:
CReference is “Client Reference” or articles that I can share with my clients.
The Technical category is articles I’ve found I might need on remote calls. Since Agenda doesn’t have a web clipper, I’m investigating other avenues, without having to use two applications.
Thanks for sharing!
Just a note that there is a Mac app called Exporter that can help exporting markdown files from Apple Notes, which can then go into Agenda. Maybe that is useful. It is in the Mac App Store.
I know about Exporter, thanks.
When I imported from Apple Notes from Agenda, the HTML entities were retained instead of being translated, but that might be because the HTML notes came from UpNote through Apple Notes. I probably should have cleaned all of them through BBEdit’s Multi-File Search and Replace before running them through Apple Notes.
I’m being more careful this time, and making them markdown through BBEdit and Rename X before importing them.
Been away for a while; UpNote can read and delete your notes and Bear doesn’t have a way to keep important frequently accessed notes visible for use.
I’ve massively simplified my project structure, with only one category for technical documents. Many reasons why I stored documents in my notes app have been flipped to the file system because I’m using MarkDownload to download files off the web. I’m going to find a pandoc GUI so that I can convert Markdown to RTF.
