How do i use “To Do”?
syncd all my calendars and reminders
I cannot figure out how to use the To do section under that overviews
I expected the To do section to show me things that I have a date of today on for reminders.
The “To Do” section shows any note that has unchecked to-do items, ie things in lists that you haven’t finished yet.
You should be able to make your own version of what you want. You can, for example, search for \due-date, which should give things that have a reminder on a given date. You could then save that as your own overview, calling it “Due” or something similar. Same with the \assigned-date for the date on the note. You could even combine the two.
Thank! It was killing me that I couldn’t figure it out. I knew it had to be simple enough. One thing, how do I edit (add/remove) an overview as you mentioned above. Thanks again
You can’t edit them as such, but you can add them and remove them. To make one, setup a search, and then click on the Save Overview at the bottom of the search panel. (Note that this is a premium feature)
To remove one, just right click on the overview on the left, or use the three dots button, and there is a delete button there.
