Horizontal ruler not working in template
Horizontal Ruler not working in Templates
Thanks for letting us know, we’ll try to fix that in the next update.
Thank you for reply…and this is another reason I love your product, and actual reply. That means more than you know - also wasn’t sure if I should post or email if I find blips in software. In any rate thank you and have a blessed day!
I use *** in a template and the horizontal rule will appear in the template when used for a note.
Update: This will be fixed in the next update.
This solved it for me.
