What I did: Not much, read the one discussion on integrating a gmail calendar - but it made no sense to me.
What happened: I continued to be lost.
What I expected: I hoped to find step-by-step directions to link my work gmail calendar to Agenda. I don’t use other electronic calendars.
In order for Gmail to work with Agenda, your Gmail calendars should first show up in the Calendar.app. You configure this in the System Preferences:
Follow the steps to authenticate with your Gmail account and check the option to sync your Calendars. After this if you go to the Calendars.app your Gmail calendars should show up:
and likewise they should then also appear in Agenda.
Hope that helps!
