Hmm, the title is a bit vague, and I can’t figure out the point from the video.
Can you write a few lines explaining the issue?
The message is in the video text.
Love headers.
Integral to my work flow with splits and merge.
Just found it odd that a tag could be formatted (functionally) as a header.
- Would be nice if tags could have a cleaner in-line format.
Should I be hearing audio in the movie? I don’t hear anything.
Is the issue related to searching for tags, or is that unrelated?
We do indeed allow tags be used in headings. We thought it made sense to allow it.
When searching for tags, it was indeed a little tricky to get a selection token that worked OK with every tag style we support. We’ll take along the suggestion. Thanks!
