The app is very, very good. However, there is one feature that is missing in the macOS app — the handwriting!
Do you think, you can add this feature to the macOS app? It would be great to use the Agenda with my Wacom tablet!
Tomasz
Tomasz
Thanks for the feedback. For now you would probably be best to create an image with the handwriting, and drag that in.
We do support various forms of handwriting on iPad, and hopefully more as Apple makes it available.
