H2 and H3 button in touchbar are switched
What I did: I put H2 and H3 in my touchbar menu, and found out that they are switched—H2 gives me a “minor heading” style and H3 give me a “Sub-Heading” style.
Things that might be helpful to know (Agenda version, OS and model, etc): Mojave (general release version), and Agenda 2.4 (latest update). 2016 Macbook pro with touchbar.
I seem to have same issue on beta 2.4 and macOS 10.13.6
Indeed, @drewmccormack has fixed it in Agenda 2.4
Huh? How is it fixed when it’s a problem for me in 2.4?
Hmm, I was pretty sure we fixed this, but will double-check
Sorry to be a bit ignorant, but I haven’t used a MacBook with a touchbar unit recently. My question is, how do you add H1, H2 (or anything else from Agenda) to the touchbar?
You are right, it’s still there, we’ll fix it ASAP. Thanks for reporting!
You can customise the touch bar using the View > Customise Touch Bar menu command.
Also, the buttons on the touchbar are often yellow when they are not active on that line. it would be easier to understand if they were always grey until or unless they are selected.
Thanks. I was trying to do it from the Apple Menu!
Ken
Yep, same as my post here from a few weeks ago: Touchbar Heading 2 & 3 Button Mapping Bug
Ok, the 2.5 update should really fix this, sorry for that!
