If I use the „Find Note“, „Add new Note“ or „Append to Note“ Action I can get the Identifier after the Action has run, to use it in the Shortcut later on - or save it in a File as Text.
It would be a great addition if I could get the Note Identifier with other Actions like the „Get Note Text“, „Get Note Markdown“ & „Get Note Summary“.
If you pass in the note into those actions, you can always extract the identifier from the same note variable as it’s a property of the note.
