What I did:Created a note for information about an event in October 2019 and corrisponding Calendar event,
What happened: Note stays at top of list
What I expected: (Actually what I hoped for) When you have 3 or 4 long notes with information about upcomming events you always have to scrole through these notes to get to notes about things happening today.
I would like to pin these notes to the bottom so I could access the daily notes easily. Any workaround would be appreciated.
Latest version Agenda and IOS
In addition to the suggestions from @Pat_Maddox I would also suggest to have a look at the navigation menu that shows when you tap/click the project title (control + 2), it allows to quickly jump to a note, but also allows flipping the note order to oldest first.
Thank you both for the helpful suggestions! I’ll probably create a category for “Future Events” and rely on tags for sorting.
What would be a nice feature:
If you create a Calendar Event on the right side of the app and “Link To Selected Note” the link is created but the note date remains the day the note was made.
If you create a Calendar Event from a note you created the note date becomes the Calendar Event date.
