Add a bullet point within the body of a note, then switch to another app and interact with it.
The bullet point (or numbering, other formatting) disappeared. I can re-add the bullet point but it’s very irritating for multitasking.
The bullet to persist without a text entry.
I am on a 2017 MacBook Pro with OSX Mojave (10.14.2) and I’m using Agenda 5.0
Thanks for the feedback. Empty lines do become body text if you leave them. We will consider whether this should be changed.
