Flexible Widget Data Bases
I would like to see a flexible way to select data basis showing in the widget. For now it’s only possible to select one data basis. A way to select several data bases (for example: Upcoming + On the Agenda) could be a better option.
I know it’s possible to add multiple widgets on iOS and macOS.
We’ll take it on board, but as you say, a simple workaround is just to use several widgets.
We’ll consider it for future updates. Thanks for the feedback!
