HI,
I was wondering if anyone is using Agenda or Findings to keep clinical notes for therapy sessions with clients, or if the developers would advise on which would be more suited to keeping track of therapy sessions.
Notes would have to be date stamped and also the date recorded if any particular note is updated or altered after initial recording.
Findings may be more suited to this. It sounds like more of an experimental log.
Agenda can add related dates to notes, but won’t update them automatically unless you have them attached to a calendar date, and you change that calendar date.
Thanks, I have both so will start working on Findings and getting on top of that. Just to say, I do enjoy both apps but am definitely not using them to the full. Thanks for the work you put into this.
