What I did: Tried to filter out checked items. For filter, I checked only included selected. also checked include unchecked items, and finally a specific tag.
What happened: Some checked items still shows. Both unchecked and checked items show. Some checked itmes are hidden (which is puzzling). The filter for the tag is working fine.
What I expected: Checked items would be hidden
Things that might be helpful to know (Agenda version, OS and model, etc): Agenda 22.3.1 Mac
Were the checked items that showed ones that had the tag?
It will include any line that matches any of the inclusion rules.
Yes, it was based on tag search. I wonder if there is a way to have a compound filter such as (Tagged and Unchecked). Thanks.
I think I figured out how to make this happen on my end. First search for a tag and unchecked as “AND” search. Afterward just filter for the unchecked items to see just the items that are unchecked. Thanks.
Glad you figured it out! Yes, currently filters work with OR logic between inclusion rules. We could look at adding AND compound filters in the future. Thanks for the feedback!
Drew,
Yes, more powerful search and filter options would make the program much more powerful.
Thanks for the consideration.
Ken
Thanks Ken, appreciate it! We’ll definitely look at making filters more powerful over time.
