Feature request: Display of links
I almost always switch the “Link”-display to “full URL view”.
That’s why I’d like to see an option that lets me change the default link display.
Thanks
Tom
Thanks for the feedback! One tip: if you paste a link into backticks (the fixed width inline style), it will show the full URL instead of the shortened version. Not quite a default setting, but it might help. We’ll take the suggestion along though!
It took a while but found it. Getting old, memory search is slowing down and not recognizing key words. I remembered a discussion regarding “to shorten or not” (and searched “link” in agenda help.) Kind of makes one want to explorer substitutions.:compass:
When you want to copy a (URL) only, insure that edit> substitutions> LINK SHORTENING is un-checked. You can then Copy as Agenda Link and paste as usual.
Good tip! That substitutions setting is handy if you always want to see the full URL. Thanks for sharing!
Great, that’s it! Thanks Bruce :slight_smile:
