Hi, I know you have collapsable sections but what I wonder is how you feel a note block would fit into this design maybe even combined into the collapsable section feature.
Im attaching two images one the note template so you see the use case, would just visually help me see things/sections better.
The second image is what I imagine the note block to look like essentially the rounded squares I see in the reminders upper left menu. Design look, not functionality is what im using that image for - the function is just to help me visually display information segments in my notes which is why I believe it would go well hand in hand with collapsable sections.
