I know there are several exporting options, incuding html, markdown, and pdf. Is it possible to export one section as a long picture format?
You mean as one big jpg or tiff? Unfortunately not at the moment. PDF is something you can convert in the Preview.app to a picture. As a workaround to avoid introducing page breaks you could set a custom (very tall) paper size in the File > Page Setup dialog before printing the note and in the print dialog choose Save as PDF.
