Excluding Tags is not working as expected
I did a search and excluded a tag.
Only notes with that tag showed up
I expected the notes with the tag not to be there
Agenda 19.2.1
Mac OS 15.1, Macbook pro M1 chip
Thanks for reporting it. We’ll look into it.
Any updates on this? I am having the same problem
I’m going to look into this soon. Thanks for bumping it!
I think I have fixed this now. It will be in the next minor release.
In the meantime, you may be able to get it to work if you make an edit to the text after setting the “excluded” option. The issue is a refresh one, so if you can force it to refresh by changing the text, and then changing it back again, it should update properly.
