If I want to export a project as a pdf file and I want to exclude specific notes. Is there a solution to tag these notes to filter them out of the report?
You can try the following:
- select the project to export in the sidebar on the left
- deselect any selected notes by clicking in the white area at the top of the project
- type CMD-A to select all notes in the project
- Cmd-click in the header of the notes you don’t want to export (aim for the little drag handle), that should deselect those notes specifically.
- Once you’re happy with the selection, choose File -> Export -> PDF
Works great, thanx a lot
