There is a problem once you attach a pdf file from spark mail and Edit from pdf Element when you save changes the icon changes it self and after a while there is no more file access and you loose every change and the file within agenda gets stuck.
Besides working with dark mode and making cut of text to copy on email the color will pass to the messege in a grey that will be invisible to read to the sender…
