Hey there,
is it possible to integrate the Eisenhower matrix (important & urgent, important & not urgent, not important & urgent, not important & not urgent) into agenda app?
It would make the agenda much easier for me
Cheers
Hey there,
Cheers
Iβm afraid Iβm not very familiar with this approach, could you describe in a bit more detail how this works? Your best bet would be the use of tags, possibly the types that take a value, see Tags, People, Emoji's, Text Actions and Links
Wonβt quick hack of simply tagging q1 - q4 and then have stored filters work for your purpose?
Bricoleur
Maybe you could use the Category as the different quadrants. And within those quadrant you can add different projects per task.
Category 1(q1)
Task
Task
Category 2 (q2)
Task
Task
Or if you use multiple method
Category 1 - Eisenhower Method
Subcategory 1 (q1)
Subproject 1 - task
Task
Subcategory 2 (q2)
Category 2 - GTD method
Something like that
