Hi there,
I’m using this app because it has a great feature: link a note to an agenda. this is a great idea and it’s a « killer feature » for a freelancer like me hopping from projects to projects.
I gripe every time I use the app for two main reaons:
Editor: it’s bad. There are tons of little behaviour issues like when you enter a bullet list, after the last item, you can not « hit return then hit delete » your way out of a list, you have to tap back to body style. It’s sub par to good editors like Bear and that’s very anoying. Also, it does not look good, but that’s a matter a taste, so less arguable, but there is far too much space between lines etc.
This, I mean why do I have to register to a community? Why is this a feature of a note app? Less of my data is better. I don’t want to go to the app store and give you a bad review because it’s really a promising app and I’m happy I test driving it, so I want to connect to you and give feedback but this is not proportional.
Thanks and good luck.
