Edit links
Is it possible to edit a link / linkname I entered like Linkname on iPadOS?
In version 9 you can now do this by placing the cursor in a link and tapping the link icon in the plus button above the keyboard. You can also use the markdown like syntax to create such links:
[linkname](http://somelink.com)
Managed once to edit the link (no way to change the name). After that I tried again but “ADD Web link” appears. Not EDIT. Link is still intact.
Here are the steps you could try:
  • tap and hold a URL
  • release when the menu with actions shows up
  • tap outside to dismiss it without any action taken (this should place the cursor right behind the link)
  • tap the plus > link icon above the keyboard
  • the top entry in the menu should now be Edit Link
I placed the cursor at the end of the line. Tapped +, Agenda crashed. Sent report.
Correction: Tapped “Edit link”, crashed then.
Got it, have fixed it in the next beta, thanks for reporting
Hi. Trying to change link name and followed the steps above. Edit link pops up change link but only shows URL but not link name. How do I change link name? Using latest version on iPad
Thanks for reporting, we’ll have a look.
