For example, a short block of notes can be completed with just a link, title, and remarks. Obviously, “reminders” can be satisfied, but it is also important to remember each link with a label. For example, when you need a link material, you suddenly want to Get inspired when you categorize your current notes with tags
I’m finding this difficult to follow. Is it that you want to link to multiple notes? You can currently link to a project, so perhaps that is an option.
Because I’m always a little crazy thinking about redundant operations, directory clicks are always cumbersome, but “agenda” is easy to grasp many operations, and the labels are very explicit
