Be nice to have an undo/redo button at top of a drawing. I’m used to this feature in other apps that support drawings/sketch. It is cumbersome to always have to use the eraser or shake the iPhone every time you want to undo just the last line of a sketch — it disrupts your flow.
Thanks for your consideration.
Thanks for the feedback, we’ll take that along.
Note that undo is there, but it is a bit hidden. You can use the system undo/redo. Either…
- Shake the device, or…
- Swipe to the left with 3 fingers (undo), or to the right with 3 fingers.
(The gestures are a bit crazy. They are Apple’s own gestures )
Nice to know. Thank you Drew.
