Drag to reorder items in/between notes
Hi folks! Absolutely loving Agenda so far—I became a subscriber as soon as I started my first project with it yesterday.
One feature that I think would create tons of potential workflow possibilities is drag to reorder items in/between notes. You know the little yellow item signifier where the Styles/Lists options pop out when you click it? What if that was draggable?
What if you could reorder items in a bullet list or task list? What if you could drag the items into other notes?
Imagine if you have a task list of things you wanted to get done for the day. Night has fallen, and you still have some unchecked tasks leftover. My current workflow is to cut/paste these tasks into tomorrow’s to-do note (and then usually fiddle around to remove the extra leftover check bubble from where I cut and add another one to where I pasted and it didn’t successfully transfer).
What if instead, you could select the items and just drag them into the other note?
Thanks for creating this already superb app. Can’t wait to see what the future brings!
Glad to hear you like Agenda so much! This all makes a lot of sense, we have a number of ideas in this direction that we would like to see ourselves as well, stay tuned!
Alex
Sounds fantastic. Great work so far!
Another one I’d love to see, especially within bulleted checklists. I am pinning to do lists at the top of each project, and it would be great to be able to reorder items by priority.
I’d also love it if completed items could automatically bump down to the bottom of a list (and get struckthru at the same time).
I find myself trying to drag the little signifier all the time.
This would be great to implement!
One more thought:
The other feature that I would love to see is an “inbox” to quickly add things to Agenda for sorting later. The ability to drag paragraph/items by the left node maks an inbox feature even more useful, because you could easily sort later.
+1 for drag to reorder and keyboard shortcut to reorder. I can imagine it should have haptic feedback on iOS.
Yes! Need this before I move all notes here.
+1 on this feature request.
I thought I was just missing how to do this. This is pretty critical.
I think that you need to add the ability to fold up sections that are under headings so that you can move entire sections with drag and drop. That would be a really good addition.
I know this is a bit old, but count this as another vote to be able to drag & drop to reorder lists, especially bulleted/dashed lists. The suggestion to make the little formatting pop-up circle be the handle is spot-on.
Drag and drop for bulleted items – pretty crucial
Folding up Lists would be a fantastic addition
Definitely +1 to this item and proposed solution.
It would be too easy to re-order a list by dragging the little circles for the pop-up formatting menu.
+1 for dragging on iOS. Tap and hold to show drag indicators?
D&D re-ordering taks lists is pretty fundamental for a task management app. Is there any news on this?
No news yet. It is certainly in the roadmap. (Competing with many other things too, I’m afraid, but we will get to it.)
I appreciate there’s probably a lot on your list, perhaps there’s another workflow for me, which currently goes something like:
My tasks have statuses: Incoming, Do Now, In Progress, Do Later and Done and I have a list for each one, moving tasks between lists as their statuses change and moving tasks up and down in lists according to priority.
Moving tasks around is klunky; select line, cut, move to newlist, paste.
Is there a better way to do this?
On MacOS I frequently use the keyboard command to move lines up and down. It’s cmd-ctrl-arrow.
+1 for dragging to reorder items/lines in Agenda (macOS is my primary tool rather than the iPad)
