I often want to keep in Agenda images that I generated in Jupyterlab (a web app + python server for data analysis).
However, drag-n-dropping images directly from Jupyterlab into Agenda does not work – nothing gets pasted (see video).
If I use Safari instead of Firefox as the web browser and attempt to drag-n-drop, the outcome is that a weird link is pasted in agenda (the link contains “data:image/png;base64 etc”)
I’m not sure what information I could provide that would help you guys.
Note that drag-n-dropping the images on the desktop works with Safari (a PNG is created on the desktop) but not with Firefox (nothing happens).
Currently my workaround is to shift-click the image to access the browser standard right-click menu, copy the image, then paste it in Agenda. It’s a bit more involved
Drag and drop can be a bit tricky. Two apps that don’t know about each other have to agree to a format, and that can go wrong.
I guess for some reason, Agenda is getting data off the pasteboard other than the image. Maybe it sees some HTML or some other format there, and thinks that is a better format (more information).
It might be worth trying holding down option as you drag/drop. Perhaps that will have an impact.
It may be tricky to get around. If Jupyterlab is putting a link of the clipboard, as well as an image, it would be difficult for Agenda to know which to pick. Forcing one or the other, as you do with the copy now, is probably the best bet.
Try dragging the images from the browser into Yoink and from Yoink into Agenda. I have been using Yoink for years and really recommend it, it’s a well designed and maintained app from a wonderful developer just like Agenda is, too.
