Is there a way to drag documents between notes?
All the time i need copy the document and paste in another note.
Therefore i wanna know if i can simplify this action.
Regards
Regards
Yes, that should certainly work. Drag the top of the note, just above the title. Drag the note to the left sidebar. Should work on all platforms.
Hmmm, I think this video can explain better.
Is there a tip?
Ah, I understand now. Sorry, I thought you wanted to drag a note between projects.
I don’t think this does work yet. The drop only works in a project where the cursor is visible, and the cursor is already in the note you are dragging from. We will see if we can improve this in future.
Thank you for the feedback
