What I did: try to add a word or pdf document by drag and drop from ios mail
What happened: a kind of link was inserted stating”view open xml document’ but the actual document was not attached. The link did not do anything either
What I expected: the document to ne attched (I seem to recall this worked before)
Things that might be helpful to know (Agenda version, OS and model, etc): ipad mini 5 ios 13
We are aware of this issue, and plan to investigate. Sorry for the trouble.
Hi, any update on this issue?
Best,
Martijn
Sorry, I’m afraid it is in a long list of things to look into. Will try to get to it.
I assume this is iOS only, right? I just dragged on the Mac from mail, and that seemed to work.
Hi, thanks for getting back to me (I appreciate you have a lot of work to do). Yes, it is on iOS only.
Pictures work, but office documents and pdf’s don’t. This is annoying, as I manage a lot of mail via my ipad.
I now use the share extension to save an attachment in apple notes, than drag from apple notes to Agenda – that actually does work, strangely enough, so the issue is strictly in the interaction with mail. I don’t know if the issue is also with other mail clients, since I am obliged to use the native app for work.
We’ll try to take a look. Thanks for reporting it.
