When I check a checklist item, it doesn’t mark the reminder as done and the same happens when I check the reminder.
Currently using version 18.3 (ios, ipados, macos)
It should work in one direction but not the other. We’ll see if this can be improved.
you mean agenda checking should mark the reminder as done, but not otherwise? Or the opposite?
I believe the other way around, marking a reminder as done should also check the list item as done, but will check
