In one project, I create several documents. I suggest to add a content or structure of documents in the side bar. I can easily to review all the document title in the project. It’s very helpful when there is lots of documents in one project
Have you seen the dropdown that appears when you click the project / overview name at the top of the notes list?
Indeed, it sounds like you’re looking for the table of content popover that @Pat_Maddox mentions, you can see it in action here:
i can see the dropdown under the category.Not the project. In one projects, there should be lots of document. I didn’t see the document tree…
Can you send a screenshot of what you’re seeing?
I think what his mean is, a catalogue for different level of title (H1, H2, H3, H4) in one note
