I always navigate to documents by clicking on the project title, main screen (where you would filter by agenda, or date, for example)
Nothing!
display list to select documents
Running on MacOs 12.2
Nothing!
Strange, does a quit and restart of the app fix the issue?
This got fixed. I think it was a bug… I had other apps hidden (only agenda visible). By mistake I made visible the rest of the apps on my Mac and all was fixed… bug, probably
Strange, let us know if it returns.
