What I did: made an edit to an already existing note
What happened: edit would disappear when returning to the note having left to look at a different note, or when moving away to another app.
What I expected: I expect edits to remain, not to disappear as soon as I stop looking at them.
Things that might be helpful to know (Agenda version, OS and model, etc): iOS 12.2 (16E5201e)
I have a screen recording showing the problem, but as a new user I am unable to upload it.
Do you mean some text disappeared? Or do you mean the cursor is not there anymore when you come back to the note?
If text is disappearing, make sure you have the very latest version of the app installed.
It’s normal the new text that I add.
For example. I might have a note that I use as a shopping list. If I add ‘apples’ to it, then close the app, ‘apples’ has disappeared when I next open the app.
I’ve got the latest version of the app.
Does it return back into view if you do some editing of the same note again?
It does not, the new text is gone for good, as far as I can tell.
Can you double check that you are on the very latest versions of Agenda on each device?
If you still have the screen capture, can you send it to drew@agenda.com?
