Dictation is no longer working on my Agenda?
What I did: Used the dictation as usual on my MacBook Pro. It either doesn’t work at all or works and then deletes it when I quit dictation.
What I expected: For it to work like ti always has.
Are you on the latest Agenda? Are you using Edit > Start Dictation?
I just did a very simple test, and was able to enter some text with dictation and it didn’t disappear. I also haven’t heard from others about it not working.
To get to the bottom of it, it would be worth quitting and restarting Agenda, and perhaps also your Mac. If it is still not working, can you describe the steps you take, how much you are dictating etc? You could also make a screen video if you like, and send it to me at drew@agenda.com
I am having this problem as well, including after a reboot of both Agenda and my Mac.
I am looking into this. It seems that if you click to end the dictation, rather than hitting a key on the keyboard, it seems to work.
Will let you know when I have a fix.
