\date doesn’t seem to work properly
I want to insert a date (today or tomorrow or whatever) so I used \date(today) or \date(1 week).
When I type that and hit the space, the “\date(today)” string disappears, but is not replaced by today’s date. (Blank)
That my shortcut be replaced by today’s date.
Version 13.0 (build 187). This works perfectly on my ipad, but not on macOS
Does it help if you type \date(format: default) once? There might have been a wrong date format stored, we fixed this in Agenda 13 but it might need this one time reset. Also note that \date(1 week) should be \date(in: 1 week)
That was it! Thank you.
Maybe I am doing it wrong??
\date(Thursday) makes it disappear?
You’ll find the supported syntax here: Creating and Using Templates - #4 by system
\date will insert the current date into the text, unless you use some of the parameters to the choose a different date than today. In this case it sounds like you would want to use \date(for: Thursday). If you don’t provide a parameter (like in: or for:), Agenda assumes what you enter is a date format according to this standard: UTS #35: Unicode LDML: Dates
