Hello,
first of all: really helpful and good looking app!
I just started to use it last week, but I’m using it more and more already. ![]()
Only one thing is a bit “frustrating” for me. I use the Apple Magic Keyboard with Trackpad for my iPad. When I want to reposition the cursor with the Trackpad the following is happening:
- I click on the new position
- the menu on the bottom disappears (the one to style the text, insert things and so on)
- the cursor disappears
- I click again on the new position
- the cursor is set to the new location and the bottom menu appears again
So there are two clicks and a fancy animation for just replacing the cursor to a new location within the same note.
If I do the same thing with my finger, it is only one tap: tap the new position for the cursor and the cursor is there - without the double-tap.
Is this intended? I could also not find any setting for this.
Thank you!
Maybe this helps too, if my “english” text doesn’t:
