Cursor position in template
Hi. Can’t find a way to specify position to place cursor each time a template used. Good to have ability to position cursor such as \cursor in a template in order to start typing at that specific position instead of having to click mouse at position each time a template is used.
Thanks for the suggestion, we’ll take a look if that can be made possible
I was just wondering the same. I would love to have a \cursor to position the cursor after loading a template
This would reduce a constant action for repositioning the cursor every time a template is inserted.
I’m experimenting with using a table inside the template. Two columns are setup. First column has labels for template elements. Second column is for data entry. TAB moves from cell to cell easily. Text will flow in the cells.
