Is there any reason why I cannot search the notes i have created. but i can search on the template projects that comes along with agenda
Do you mean searching a word in your notes does not work?
Note that very short words, like “a”, may be excluded from the search. Try a longer word.
If it doesn’t work, try restarting Agenda, and see if that helps.
Finally, are you using “Search All”? The search bar at the top is only for the current project, unless you use the “Search All” on the left.
