It’s indeed not very well documented, we’ll make it more clear.
I am trying to use event-date in a template to get the following date output for a linked calendar event in my notes text.
Tuesday, 18 April 2023 at 03:00 pm
or Day, dd MMMM yyyy at h:mm a
I am defining the format as below…
\event-date(start: format: EEEE\, dd MMMM yyyy) at \time(format: hh\:mm a)
What am I doing wrong?
You would have to use:
\event-date(start: EEEE\, dd MMMM yyyy 'at' hh\:mm a)
Oh ! Realised my mistake… All works as expected now.
Thank you for the wonderful support.
Is there a way to prevent event notes or attendees (or both) from rendering alongside the template? I’m using cmd+click, Create New Note from Template… and my template just has a short outline in it. I don’t want to see anything else.
Use case: I have some meetings where I don’t care about recording the attendees but I want the Agenda note to sync to the date and time of the meeting.
You can do this by using the right placeholders, as shown here Creating and Using Templates - #4 by system, like \event-title and \event-date
clipboard placeholders inside codeblock not working, Is this supported, if not can it be added in future releases?
Also if there is no space before the placeholder then it doesn’t work, is there a workaround for that
I think the problem with placeholders in code or preformatted text is that the placeholder may be part of the code. Code can have backslashes etc, and we generally don’t want to interpret those as actions for Agenda.
Perhaps there is a workaround. We’d have to think about it. But in general, you don’t want Agenda interpreting the code as actions.
We will consider the space issue as well.
Is there a way to apply a Template to an existing note?
If I start drafting a note and then want to apply the template to it, I can’t find a way to do that, need to create a new note from template then copy content…
I’m afraid you can’t do that, no. The template is really just some text, and it would have no way to match up what you have in your note with the template. Eg. If you had a title in your note already, is that the title from the template? That sort of thing.
We’ll take it along. Maybe we can do something with it in future.
For now, you could create a new note, and copy the content over, or you could create a new note and join the two notes together.
This sounds like something that Apple Intelligence could be used for….
Yes, for sure. It certainly can help with generating titles from an existing body of text. We’ll look into it.
I’m joining in here, would also very mich appreciate to have a placeholder for the Project Name.
Adding the project name when creating a calendar event would be helpful. I regularly have to add the project name manually to make the calendar entry useful, as I have similar entries for each project.
Custom Metadata placeholders would be even better: I’d love to be able to populate projects with my own metadata (project ID, project type, client for example and add these to Agenda templates or calendar events via placeholders.
Good idea. We’ll take it along. Thanks!
