If you create a new note in Agenda from a calendar event, all the information associated with the event gets copied across. I find this annoying as it clutters up the note, especially if I’m writing on an iphone, however its not so easy on an iOS device to delete quickly. A way of deleting this information quickly (like having it selected from the start, so its easy to delete) would be very helpful. Alternatively, perhaps the information could be copied to a subsection of the note so that it can be collapsed most of the time: that way perhaps you’d have the best of both worlds - a record of the event in case the event is deleted in the calendar, without it cluttering what you are writing.
Best wishes,
Tim
Thanks for the feedback, we’ll think about how this can be improved indeed.
